I'm a little confused as to what was working for you. I can explain what I saw when I used the serial flash programmer from the command line.
I had a distribution that contained and .elf, .sof, .cdf and .jic files. I was using the serial flash programmer from the command line. The programmer would actually claim that it successfully updated the flash - however, after a reset the FPGA was unable to configure from the flash device. In other words, the serial flash programmer is not a good way to tell if the flash chip is OK.
Are you in a position to try a new chip on your board?
Seth
