17 years agoNiosII IDE finding no Nios
I have had to rebuild my development environment on a new laptop. I have been using the Nios IDE from Quartus v6.1 to v7.2 without too many problems, with the public eCos.
I installed the v8 + SP1 and found that I could no longer build, so I've gone back to 7.1, after deleting all mention of Altera from the registry, in addition to a full uninstall. The error msg (below) generated when building a Hello, world (no OS yet!), makes me think that I must have to run Quartus first - I've pulled the file set archived by Quartus out of Sourcesafe, but install.ptf does indeed contain no nois's - only blocks of Altera IP. Sadly Quartus 7.1 won't accept the .qpf as they were built on fpga engineer's PC with Q7.2, or possibly even 8.0. So does anyone know - do I have to treat Quartus' several install.ptf's as part of the file set that must be sourcesafe'd for version control ( I have found several install.ptf's in various directories on my other PC, so I'm not sure which ones matter). Thanks! Ken ERROR: module cpu (altera_nios2) not found in component directory (install.ptf) 07-Oct-2008 17:01:49 - (SEVERE) generate: java.lang.IllegalStateException: java.lang.IllegalStateException: com.altera.ingenuous.GTFElement.GTFElementErrorException: <error> element in GTF script make: *** [/cygdrive/c/SourceSafe/Talisker/HeadBoardFPGA/quartus_build/software/hello_world_1_syslib/Debug/system_description/../obj/generated_all.mk-t] Error 1
