12 years agoHi, I am also trying to get "Nios II stand-alone flash programmer" work in Windows.
But I cannot be successful. I do same thing as you about 5 intalling steps. And then I do not know how to do about next Run steps. 1. Open a command prompt on the stand-alone computer. Change directories to the location of the files you wish to program into flash memory. 2. Run thenios2-flash-programmerutility as described inChapter 3, Using the Flash Programmer from the Command Line. My qestion: a. How to open "a command prompt"? b. Is "a command prompt" the Nios II Command Shell? if yes, where is it ? Thanks.
