NIOS V Sysnthesis Fails with Quartus 25.1 Lite
Hi all,
Rather than Adding QSYS into project, please add QIP into the project. From 25.1std, the tool supports QIP only due to a change in Quartus compiler.
The tool also prompts with message below.
You may find a qip file located in the same folder of qsys system top level hdl file under project directory liking this.
*Copied from ERROR building simple NIOSV Compact project | Altera Community
Liang Yu
LiangYuG_Altera Yes, this sorted the problem out for me. The project builds fine now.
Can I ask if you know what the motivation for this change was? QIP files are generated output, it doesn't make a lot of sense to add what is essentially a temporary file as project member. The QSYS file is the source of truth of the design. In previous versions, Quartus would create the QIP file in the db directory (another temporary folder) during synthesis. As it no longer does this, one can end up accidentally including an outdated QIP file into the project (which I have just experienced and spent a while debugging until I realized the mistake).
