Nios II SBT Crashing on Linux
- 6 years ago
The following workaround seems to work, it essentially replace Quartus included java engine with Java 8
cd ..../intelFPGA/20.1/quartus/linux64
mv jre64 jre64_old
ln -s /lib/jvm/java-1.8.0-openjdk-amd64/jre jre64the path to Java 8 jre might be machine specific, mine is at least placed there
hi Eliath Guzman
Do you have any news about this, because I have the same problem
Hi everyone,
It seems to be an error in GTK
OpenJDK 64-Bit Server VM warning: ignoring option MaxPermSize=256m; support was removed in 8.0
(Eclipse:225473): Gtk-WARNING **: 22:27:00.086: Negative content width -6 (allocation 1, extents 4x3) while allocating gadget (node toolbar, owne
r GtkToolbar)
(Eclipse:225473): Gtk-WARNING **: 22:27:00.086: Negative content height -6 (allocation 1, extents 4x3) while allocating gadget (node toolbar, own
er GtkToolbar)
free(): invalid pointer
- SDevaux5 years ago
Hi everyone and @Eliath_G_Intel ,
I found a solution :
run in konsole:
export SWT_GTK3=0
export SWT_WEBKIT2=1
./eclipse-nios2and GUI will be launched correctly
Stephane,
FPGA R&D engineer
