VKoto's avatar
VKoto
8 years ago
NIOS II - UART
I have a problem with compilation my project in Eclypse. Compilation was stopped as you can see in attachment. Do you have some ideas what I was doing wrong?
Thank you for your answers.
  • Abe's avatar
    Abe
    I was able to recreate your issue.. and the solution is quite simple ... just include the following line in your code and the error will go away..
    #include "altera_avalon_uart_regs.h"
    The project compiles without any issues now. Try it and see if it works out.
  • VKoto's avatar
    VKoto
    thank you for your answer. But I have problem with include #include "altera_avalon_uart_regs.h". Eclypse write me:
    Multiple markers at this line
    - Unresolved inclusion: "altera_avalon_uart_regs.h"
    - fatal error: altera_avalon_uart_regs.h: No such file or
    directory
    Do you have any idea how can I resolve this problem? Thank you.
  • Abe's avatar
    Abe
    Have you configured your BSP when you created it using Eclipse.? If not, then select the uart BSP top most project and right-click it. From the menu, look for NIOS II -> BSP Editor.
    This will open up the BSP editor . Select the "Settings" option in the left pane. Here you need to make the following changes.
    Select/Enable only the following 4 options :
    *enable_instruction_related_exceptions_api
    *enable_small_c_library
    *enable_reduced_device_drivers
    *allow_code_at_reset
    Uncheck all other options. Click "Generate" and then Exit. Now, go to Eclipse and build the BSP and application again. This time it should compile without any errors.
    I've included the same project with the software built in this ZIP file. You can have a look at it.
  • VKoto's avatar
    VKoto
    Than you very much. Everythink works.
