SThor8
6 years agoNios Eclipse crashes, free(): invalid pointer
Hi
When starting nios ii from quartus the eclipse splash screen appear a short moment and then nothing happend.
Starting eclipse from the prompt result in the following error message
> ~/intelF...
- 6 years ago
The following workaround seems to work, it essentially replace Quartus included java engine with Java 8
cd ..../intelFPGA/20.1/quartus/linux64
mv jre64 jre64_old
ln -s /lib/jvm/java-1.8.0-openjdk-amd64/jre jre64the path to Java 8 jre might be machine specific, mine is at least placed there
SThor8
6 years agoThe following workaround seems to work, it essentially replace Quartus included java engine with Java 8
mv jre64 jre64_old
BoonBengT_Altera
Moderator
6 years agoGood to know that it is working now, we would be closing the thread. If you have further queries, Please do post a response in the next 15 days.
After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
Warm Regards
