Mahdi
5 years agoNIOS 2 custom instruction including Partition Database File (.qdb)
I am creating a custom instruction in Platform Designer as a new component. My question is if I can add .qdb files as a part of component files? Or, I am allowed to only add HDL files?
My cu...
BoonBengT_Altera
Moderator
5 years agoHi @Mahdi,
Thank you for posting in Intel community forum, hope this message find you well.
Per my understanding, you only need to specify the synthesis HDL files for your custom instruction. (only allowed)
Interesting design you have, would recommend to add the HDL and try compile the design.
Best Wishes
BB
Mahdi
5 years agoHi,
Thanks for your reply. Actually, I was able to compile the design at the end. What I did for my issue was to add only the blackbox module into the custom instruction, and then, after analyzing and synthesizing the design, I manually add the .qdb file to that specific blackbox module. Fortunately, this method worked and I can see that the .qdb file exists in the chip planner.
