9 years agoNewbie vs VHDL: season 01 episode 01
Hi all Since I am new to VHDL I have some questions (that probably you will find trivial): 1. Is good practice to define a behavioural architecture with one single process inside or it is ...
9 years agosynchronisation means using a clock. The template is:
process(clk, reset)
begin
if reset = '1' then
-- reset goes here
elsif rising_edge(clk) then
--synchronous stuff goes here - including state machines
case state =>
when state1 =>
-- do something
....etc
end case;
end if;
end process;
The good thing about doing a state machine this way is you only need a single process, and you will never get latches.
