8 years agonewbie question: synchronous versus combinational bus mux using case statement
Hello all- Can anyone explain why the first (synchronous) version below compiles in quartus, but the second (combinational) does not? In the 2nd case the error is: Error (10137): Verilog ...
8 years ago --- Quote Start --- This is a quirk of Verilog. Reg is just a data type in the Verilog. What it maps to in logic is down to the behavior in the code. It is just unfortunate they chose the name "reg" --- Quote End --- Yes, indeed, sir. I found both the code snippets below generate the desired combinational logic. I would guess the 2nd one might be frowned upon. Would you be able to recommend a book that covers these sorts of issues? It would be nice to find one that is written in Verilog 2001. Thanks again, -J
always @ (KEY,count)
case(KEY)
0 : LED = count;
1 : LED = count;
endcase
always @ (KEY)
case(KEY)
0 : LED = count;
1 : LED = count;
endcase
