10 years agoNewbie Qsys Question
Hello, here's a quick question, does using Qsys imply that one must instantiate a Nios processor? I'm looking at using Rapid Serial IO or PCIe on my FPGA to interface with a TI DSP chip. But I don't ...
10 years ago --- Quote Start --- why would you want to use Qsys if there isn't a processor involved? I don't see what it buys you. --- Quote End --- Qsys let's you connect a variety of IP blocks relatively easily and it will generate the necessary instantiation and interconnects. Whether or not it is a net positive or negative probably depends on the scope of your system, and likely doesn't have anything to do with whether or not you have a processor in it or not. TI DSP -> (PCIe or SRIO or addr/data bus or SPI or I2C or ...) -> [Qsys] -> various peripherals That's a relatively straight forward system to produce. Personally I think if you're talking about more than a couple peripherals, or are involving any memory controllers / DMA, Qsys makes sense.
