9 years agoNew to FPGA programming - Please Help
Hello all, I am new to both this forum and FPGA with OpenCL - I have some questions I hope someone can help me with. I have intelFPGA_pro v 16.1 installed in Ubuntu Linux OS and am just tr...
9 years agoNallatech has a document named "Nallatech OpenCL A10 BSP Getting Started Guide". You can get the document from their support section. You should read and follow that document to update the FPGA image via PCI-E to enable the PCI-E core, and install the driver. Note that Nallatech does not officially support Ubuntu and the driver will very likely not work on that OS. Nallatech recommends using CentOS v6. Kernel compilation will likely work on Ubuntu, though.
