10 years agonetwork analyzer
Hey everybody. as a part of my studies i have to build an HW network analyzer, i will use the altera-DE2. at the begin i should get and receive eth packet (the information that i need is till leve...
10 years agoYou can learn a lot just by running through an existing example.
Look at http://www.alterawiki.com/wiki/nios_ii_udp_offload_example Get it up and running, then examine the UDP receive processing. Replace it with logic to support your analyzer functions. If nothing else, should give you a very good idea how to process the Ethernet frames in this environment.
