Nested SystemVerilog/Verilog Include Files
- 5 years ago
I think the problem is the fact that you declared a typedef in a header file. Because they're usually declared in a verilog HDL file before the module declaration, but I don't think that's what you want to do.
Header files are problematic in general, which is why SystemVerilog introduced us to packages: https://ieeexplore.ieee.org/stamp/stamp.jsp?tp=&arnumber=6469140
You should use packages instead of `include. You can populate packages with parameters too.
Nurina
Hi Nurina, ok thanks Il convert it to a package. It is a Xilinx project that I am importing and works there.
David
Hi David,
Nurina
P/S: If you like my comment, feel free to give Kudos. If my comment solved your problem, feel free to accept my comment as solution!
