12 years agoRysc,
I compiled my design an ran TimeQuest again with the same SDC file. There are still violations: --- Quote Start --- Setup violation on: pll|clk[2]: -4.961 slack, -777.139 End Point TNS Hold violation on: pll|clk[2]: -4.464 slack, -12.867 TNS, 48MHz....safe_q[0]: -0.610 slack, -0.610 TNS, 96MHz....safe_q[0]: -0.007 slack, -0.007 TNS --- Quote End --- How do i solve these? Should i put constraint on the paths? There are a lot of Failing Paths for the pll. EDIT: I solved the Hold violations by putting a Multicycle constraint of 1 cycle between the clocks. The Setup violation is between Nodes, and a lot of nodes, instead of clocks, should i use the same multicycle approach?
