12 years ago[QUOTE=Rysc;178810
- Why not use derive_pll_clocks instead of manually entering the generated clock assignments? --- Quote End --- Hi Rysc, This is somewhat OT here, but I take advantage of your comment to ask your expert advice on this subject. I often chose the create_clock command instead of derive_pll_clocks in order to define the clock domains with simple mnemonic names: i.e. clk50mhz whereas derive_pll_clocks would have generated obscure names like inst5|altpll_component|auto_generated|pll1|clk[0] I've never used TQ extensively, since i focused mainly on other fpga design issues, so I never inquired if there was a better way to do this, still exploiting the automation offered by derive_pll_clocks. I think it's possible. But how?
