15 years ago --- Quote Start --- Hello everybody, In my top level design in Quartus I am trying to feed the LSB of two buses with a signal which comes out of a block, usually I do this by naming the output signal the same name as the LSB of the bus: lv_to_uc_status_i[0] But I cannot name the output signal twice, so how can I tell Quartus that I need to feed two buses with this signal ? Thanks, Eric --- Quote End --- Hi Eric, what are you using Verilog, VHDL schematics Kind regards GPK
