11 years ago --- Quote Start --- Actually I'm doing some research for FPGA chip testing. I need to download the configuration file into the chip and get the inputs of the chip fixed on some specific values.(eg: there are five inputs of a circuit and these inputs are fixed on '10010') So I'm considering to edit the configuration files but I don't know whether I can achieve my purpose using tools provided by Altera. Is there any tool can be helpful? --- Quote End --- You should be able to use JTAG commands, along with a BSDL file to set bits in I/O cells. File a Service Request with Altera and ask them specifically how you can use JTAG to control the FPGA I/O pins using BIST (built in self test) commands. I've never used this feature before, but others on the list may have. --- Quote Start --- Also, you mentioned the format is proprietary. Can I find it out by searching the patents? --- Quote End --- Maybe. But its not really worth your time, given that the documented JTAG BIST commands and published BSDL files contain the information you need for these specific tests. Cheers, Dave
