10 years agoNeed Pin Assignment for Cyclone III Starter Kit
Hi, I am using Cyclone III EP3C25F324 FPGA and need the Excel sheet for pin assignment to map Quartus and my board.I want to manually map the pins.I am facing problem at this step. Once I go the ...
10 years agoThe pins position and mapping should be in the datasheet. Once you did your mapping you can export the assignments so you can import them in a later project. Some board vendors have already done this for you and you ca download the assignments from their website.
