booman
3 years agoNeed help with using an entity from a different project (error: 10481)!
I need to use a entity 'task3' from a different project 'lab3' the file name I need it from is also 'task3'. My current project is 'lab4' . I am trying to port map but have been unsuccessful please h...
Nurina
3 years agoHi,
It seems like the files/library are not added to your project. You can use either methods:
- Add file to project. On Quartus go to, Project>Add/Remove Files in Project>Files
- Add library to project. On Quartus go to, Project>Add/Remove Files in Project>Library. You can also do this on .qsf: https://www.intel.com/content/www/us/en/programmable/quartushelp/17.0/mapIdTopics/jka1465598291051.htm
Nurina
