10 years agoNeed help with testbench driving serial data out @ different clock rates, Please :)
TestBench fills an 8 bit by 16 registers array with random numbers then serially shifts it to the TDM serial input. The TDM will be coming from a Sharc DSP @ 8bit x 16 slots and continuous frames and...
10 years agoAn alias will do nothing on its own. You can only write the data at the correct rates it's you write the code to do so.
