10 years agoNeed help with testbench driving serial data out @ different clock rates, Please :)
TestBench fills an 8 bit by 16 registers array with random numbers then serially shifts it to the TDM serial input. The TDM will be coming from a Sharc DSP @ 8bit x 16 slots and continuous frames and...
10 years agoHi there, thanks for your reply. I did 2ns so I don't have to press a lot of F9 to run the simulation. Don't know if it makes any sense, any how. I didn't quite understand the second and third points. Please bear in mind that the data needs to go to each sdi @ different clock rates simultaneously. I would appreciate a sample code just to know from where to start. Cheers
