12 years ago
Need Help with Sequence detector Code errors
Hello All,
I am trying to create a finite state machine which detects the input sequence 1011. I have written the code however I am getting about 21 errors. I am new to VHDL so what looks syntactically correct to me may be totally wrong. I would greatly appreciative if there is anybody who could take a look at my code and offer some advice as to what is creating the errors. My code is attached. Thanks
    --- Quote Start ---
    Hello All,
    --- Quote End ---
    The simplest way to detect a sequence is to use delay to remember past values(shift register):
    in a clocked process use signal temp of 4 bits then
    temp(3) <= data;
    temp(2) <= temp(3);
    temp(1) <= temp(2);
    temp(0) <= temp(1);
    if temp = "1011" then
        sequence <= '1';
    else
       sequence <= '0';
    end if;
    you can also just code
    temp <= data & temp(3 downto 1);
    you may reverse the shift direction depending on which way suits your sequence sense.
    temp <= temp(2 downto 0) & data;
