12 years ago --- Quote Start --- Hello All, I am trying to create a finite state machine which detects the input sequence 1011. I have written the code however I am getting about 21 errors. I am new to VHDL so what looks syntactically correct to me may be totally wrong. I would greatly appreciative if there is anybody who could take a look at my code and offer some advice as to what is creating the errors. My code is attached. Thanks --- Quote End --- The simplest way to detect a sequence is to use delay to remember past values(shift register): in a clocked process use signal temp of 4 bits then
temp(3) <= data;
temp(2) <= temp(3);
temp(1) <= temp(2);
temp(0) <= temp(1);
if temp = "1011" then
sequence <= '1';
else
sequence <= '0';
end if; you can also just code temp <= data & temp(3 downto 1); you may reverse the shift direction depending on which way suits your sequence sense. temp <= temp(2 downto 0) & data;
