15 years ago
need help to design calculator function (addition and multiplication)
i need to design calculator that performs operations of addition and multiplication of 2 input (5-bit binary) that representing signed decimal numbers (range, -16 to + 15). I've already done the coding but now i'm stuck in BCD and seven segment coding..can anybody help me :cry:
module calculator (a,b,outadd,outmul, add,mul,clk);
input signed [4:0] a ;
input signed [4:0] b;
input add , mul;
input clk;
output reg [5:0] outadd;
output reg [9:0] outmul;
always @ (posedge clk)
begin
if (add)
outadd <= a + b;
begin
if (mul)
outmul <= a * b;
end
end
endmodule
    Where is the module name?
    sevsegment_1 (bcd_1,out1);
    should be
    7segment sevsegment_1 (bcd_1,out1);
    got problem when i want to adding in negative side at bcd...example -16-16 =-32, in bcd the answer is 992...why this thing happen...
    I have told before, how negative numbers can be treated. You can't apply BCD conversion to 2s complement number representation.
    I already invert the negative using this coding, but the answer still same
    always @ (*)
    begin
    if (resulta[9]==0)
    inv=resulta;
    else if (resulta[9]==1)
    inv = ((~resulta)+5'b00001);
    --- Quote Start ---
    --- Quote End ---
    Effectively impossible in my opinion.
