15 years agoIt's incorrect module instantiating syntax, I think. You made the BCD decoding more complicated than necessary. Hopefully the design compiler will drop redundant calculations.
Finally, negative numbers aren't handled correctly, I fear. The BCD decoder doesn't work for 2s complement, negative numbers have to be converted to sign/magnitude first. You have to consider how to display the sign, by the way.
