15 years agohi,hamema.
I will tell you two things. one is 7segLED. see attached file. a means LED's 0 pin b means LED's 1 pin .... g means LED's 6 pin the dot means LED's 7 pin the second thing is... just use case sentence. when you get value "0" set each pin like that. ------------------ verilog HDL logic ------------------- case ( outadd ) 0: begin a = 0;//(negative logic ) b = 0; c = 0; d = 0; e = 0; f = 0; g = 1; dot = 1; //whatever end 1: begin a = 1; .... endcase ----------------------------------------------------------- do you get what I say?
