12 years ago
Need Help in Infra red Module
Hi all
I am doing a project which i need to include the Infrared Module inside. Basically i need to control the seven segment on the DE2_115 board via the remote control given in the box itself. I have another already working counter module which control the key on the board itself to allow the seven segment to jump as the counter count. However, when i add the IR demo module which is working and i get from the site : " https://code.google.com/p/embeddedrobot/source/browse/trunk/+embeddedrobot+--username+preston0769%40gmail.com/de2-115_systemcd/de2_115_demonstrations/de2_115_ir/de2_115_ir.v " only the key on the board manage to control , the remote control fail.
Below is my modify code structure. Kindly advice.
code :
module updowncount(input iclk1hz,irst,ireset,iup,idown,
input iDATA_READY,
input [31:0] iDATA,
output reg [7:0] otvalue,otvalue1,otvalue2,otvalue3);
always@ (posedge iclk1hz or negedge irst)
begin
if (~irst)
otvalue<=127;
else
if(iDATA[15:0] == 16'hA15E )
otvalue<=otvalue+1;
else
if(idown==0 || iDATA[15:0] == 16'hE11E)
otvalue<=otvalue-1;
else
if(ireset==1)
otvalue<=otvalue;
else
otvalue<=otvalue;
end
Thanks Every1
    Ok. I don't know exactly what you are attempting with your code, but I'm seeing several things that are suspect.
    iup is never used.
    ireset is extranious, (both =1 and =0 case does the same thing)
    otvalue1, otvalue2 and otvalue3 are never used.
    iDATA_READY is never used.
    Only 16 bits of iDATA are used.
    So based on this, I'm seeing this functioning as follows;
    At irst = 0, the otvalue is set to 127.
    if iDATA[15:0] == 16'hA15E, you count up. But this is not qualified by iDATA_READY.
    if idown==0 or iDATA[15:0] == 16'e11e you count down. Again not qualified by iDATA_READY.
    Otherwise the value is held at it's current count.
    Let me know what you are seeing that is wrong. My guess, is since you are not qualifying with iDATA_READY, you are getting stuck with it continously counting down or up based on the current state of iDATA[15:0]
    Pete
    Hi anakha,
    I am adding a IR Module that i have found in the net to the existing updowncount module.
    I have test my existing module and is working well.
    This is how my existing module work.
    At irst=0 (which is key0 on the DE2 board) otvalue is set to 127.
    At iup=0 (which is key1 on the DE2 board) otvalue will start to count up
    At idown=0 (which is key2 on the DE2 board) otvalue will start to count down.
    Now i want to add an IR module so i can control it via the remote control as well as the key on the de2 board.
    This is the IR demo module i found online which i have test it and it work too.
    Below is the code :
    module IR_RECEIVE(
    iCLK, //clk 50MHz
    iRST_n, //reset
    iIRDA, //IR code input
    oDATA_READY, //data ready
    oDATA //decode data output
    // PARAMETER declarations
    parameter IDLE = 2'b00; //always high voltage level
    parameter GUIDANCE = 2'b01; //9ms low voltage and 4.5 ms high voltage
    parameter DATAREAD = 2'b10; //0.6ms low voltage start and with 0.52ms high voltage is 0,with 1.66ms high voltage is 1, 32bit in sum.
    parameter IDLE_HIGH_DUR = 262143; // data_count 262143*0.02us = 5.24ms, threshold for DATAREAD-----> IDLE
    parameter GUIDE_LOW_DUR = 230000; // idle_count 230000*0.02us = 4.60ms, threshold for IDLE--------->GUIDANCE
    parameter GUIDE_HIGH_DUR = 210000; // state_count 210000*0.02us = 4.20ms, 4.5-4.2 = 0.3ms < BIT_AVAILABLE_DUR = 0.4ms,threshold for GUIDANCE------->DATAREAD
    parameter DATA_HIGH_DUR = 41500; // data_count 41500 *0.02us = 0.83ms, sample time from the posedge of iIRDA
    parameter BIT_AVAILABLE_DUR = 20000; // data_count 20000 *0.02us = 0.4ms, the sample bit pointer,can inhibit the interference from iIRDA signal
    // PORT declarations
    input iCLK; //input clk,50MHz
    input iRST_n; //rst
    input iIRDA; //Irda RX output decoded data
    output oDATA_READY; //data ready
    output [31:0] oDATA; //output data,32bit
    // Signal Declarations
    reg [31:0] oDATA; //data output reg
    reg [17:0] idle_count; //idle_count counter works under data_read state
    reg idle_count_flag; //idle_count conter flag
    //wire idle_count_max;
    reg [17:0] state_count; //state_count counter works under guide state
    reg state_count_flag; //state_count conter flag
    reg [17:0] data_count; //data_count counter works under data_read state
    reg data_count_flag; //data_count conter flag
    reg [5:0] bitcount; //sample bit pointer
    reg [1:0] state; //state reg
    reg [31:0] data; //data reg
    reg [31:0] data_buf; //data buf
    reg data_ready; //data ready flag
    // Structural coding
    assign oDATA_READY = data_ready;
    //idle counter works on iclk under IDLE state only
    always @(posedge iCLK or negedge iRST_n)
    if (!iRST_n)
    idle_count <= 0;
    else if (idle_count_flag) //the counter works when the flag is 1
    idle_count <= idle_count + 1'b1;
    else
    idle_count <= 0; //the counter resets when the flag is 0
    //idle counter switch when iIRDA is low under IDLE state
    if (!iRST_n)
    idle_count_flag <= 1'b0;
    else if ((state == IDLE) && !iIRDA)
    idle_count_flag <= 1'b1;
    else
    //state counter works on iclk under GUIDE state only
    if (!iRST_n)
    state_count <= 0;
    else if (state_count_flag) //the counter works when the flag is 1
    state_count <= state_count + 1'b1;
    else
    state_count <= 0; //the counter resets when the flag is 0
    //state counter switch when iIRDA is high under GUIDE state
    if (!iRST_n)
    state_count_flag <= 1'b0;
    else if ((state == GUIDANCE) && iIRDA)
    state_count_flag <= 1'b1;
    else
    //data read decode counter based on iCLK
    if (!iRST_n)
    data_count <= 1'b0;
    else if(data_count_flag) //the counter works when the flag is 1
    data_count <= data_count + 1'b1;
    else
    data_count <= 1'b0; //the counter resets when the flag is 0
    //data counter switch
    if (!iRST_n)
    data_count_flag <= 0;
    else if ((state == DATAREAD) && iIRDA)
    data_count_flag <= 1'b1;
    else
    data_count_flag <= 1'b0;
    //data reg pointer counter
    if (!iRST_n)
    bitcount <= 6'b0;
    else if (state == DATAREAD)
    begin
    if (data_count == 20000)
    bitcount <= bitcount + 1'b1; //add 1 when iIRDA posedge
    end
    else
    bitcount <= 6'b0;
    //state change between IDLE,GUIDE,DATA_READ according to irda edge or counter
    if (!iRST_n)
    state <= IDLE;
    else
    case (state)
    IDLE : if (idle_count > GUIDE_LOW_DUR) // state chang from IDLE to Guidance when detect the negedge and the low voltage last for > 4.6ms
    state <= GUIDANCE;
    GUIDANCE : if (state_count > GUIDE_HIGH_DUR)//state change from GUIDANCE to DATAREAD when detect the posedge and the high voltage last for > 4.2ms
    state <= DATAREAD;
    DATAREAD : if ((data_count >= IDLE_HIGH_DUR) || (bitcount >= 33))
    state <= IDLE;
    default : state <= IDLE; //default
    endcase
    //data decode base on the value of data_count
    if (!iRST_n)
    data <= 0;
    begin
    if (data_count >= DATA_HIGH_DUR) //2^15 = 32767*0.02us = 0.64us
    data[bitcount-1'b1] <= 1'b1; //>0.52ms sample the bit 1
    end
    else
    data <= 0;
    //set the data_ready flag
    if (!iRST_n)
    data_ready <= 1'b0;
    else if (bitcount == 32)
    begin
    if (data[31:24] == ~data[23:16])
    begin
    data_buf <= data; //fetch the value to the databuf from the data reg
    data_ready <= 1'b1; //set the data ready flag
    end
    else
    data_ready <= 1'b0 ; //data error
    end
    else
    //read data
    if (!iRST_n)
    oDATA <= 32'b0000;
    else if (data_ready)
    oDATA <= data_buf; //output
    endmodule
    So now i am having problem to modify my updowncount module.
    I tried to write the code in several ways but is still fail.
    kindly advice me =D
