14 years ago
need help: frequency div
hello everyone, i am trying to do a frequency divider which convert 33.333Mhz to 1hz frequency, the code don't show any error after compilation, but my result is all zero after simulation. can anyone please help me
the following is the code:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity clk_gen is
port( Clk : in std_logic;
Clk_mod : out std_logic
end clk_gen;
architecture Behavioral of clk_gen is
signal clkdiv : unsigned(24 downto 0);
signal clk1hz : std_logic;
begin
process(Clk)
begin
if rising_edge (Clk) then
clkdiv <= clkdiv + 1;
end if;
end process;
clk1hz <= clkdiv(24);
Clk_mod <= clk1hz;
end Behavioral;
    --- Quote Start ---
    Its up to you to write the testbench. Use this as an opportunity to learn. Look, lots of people are helping you already!
    Try and create a testbench, and post the code, along with questions, when you have trouble.
    Start with the example I posted here:
    http://www.alteraforum.com/forum/showthread.php?t=32386
    Cheers,
    Dave
    --- Quote End ---
    ok..then i try my best....thanks for helping me...
