11 years agoNeed advice about coding style
Hello I'm Alex and I am novice for VHDL coding. if my english awful pls forgive me. I trying to understand VHDL PROCESS statement. I try with 1bit full adder with carry save function in Quartus2 v...
11 years agoHow about such cutting for sensitivity list when describing FSM? I know that is very badexample with impure function instead of process but ... quartus eats it up.
library ieee;
use ieee.std_logic_1164.all;
entity fsm is
port(
clk,
enable_SM,
start,
pk_eq_k,
pn_eq_n : IN std_logic;
pk0,
pkp1,
pn0,
pnp1 : OUT std_logic
end fsm;
architecture v1 of fsm is
type state_type is (s1, s2, s3, s4);
impure function next_state(st : state_type) return state_type is
begin
case st is
when s1 =>
if start= '1' then
return s2;
else
return s1;
end if;
when s2 =>
return s3;
when s3 =>
if pk_eq_k = '0' then
return s3;
else
return s4;
end if;
when s4 =>
if pn_eq_n = '0' then
return s4;
else
return s2;
end if;
end case;
end next_state;
signal
st : state_type;
begin
process(enable_SM, clk)
begin
if enable_SM = '0' then
st <= s1;
elsif rising_edge(clk) then
st <= next_state(st);
end if;
end process;
pk0 <= '1' when (st = s1 or (st = s4 and pk_eq_k = '1')) else '0';
pkp1 <= '1' when st = s3 else '0';
pn0 <= '1' when st = s2 else '0';
pnp1 <= '1' when st = s4 else '0';
end v1; The code above ... struck me so / really assignment to signal operators imply implicit processes . so i change a little bit behaviour to fsm architecture v2 of fsm is
signal st : state_type;
procedure state_transition is
begin
case st is
when s1 =>
if start= '1' then
pk0 <= '1';
st <= s2;
else
pk0 <= '0';
st <= s1;
end if;
pkp1 <= '0';
pn0 <= '0';
pnp1 <= '0';
when s2 =>
pn0 <= '1';
pkp1 <= '1';
pk0 <= '0';
pnp1 <= '0';
st <= s3;
when s3 =>
pk0 <= '0';
pkp1 <= '1';
pnp1 <= '0';
st <= s3;
else
pk0 <= '1';
pkp1 <= '0';
pnp1 <= '1';
st <= s4;
end if;
pn0 <= '0';
when s4 =>
pnp1 <= '1';
st <= s4;
else
pnp1 <= '0';
st <= s2;
end if;
pkp1 <= '0';
pn0 <= '0';
pk0 <= '0';
end case;
end state_transition;
begin
process(enable_SM_n, clk)
begin
if enable_SM_n = '1' then
st <= s1;
pn0 <= '0';
pkp1 <= '0';
pk0 <= '0';
pnp1 <= '0';
state_transition;
end if;
end process;
end v2; but all is fine until you you catch multiple assignments. by the way ... (why my rang became as written? is it joke?)
