11 years agoNeed advice about coding style
Hello I'm Alex and I am novice for VHDL coding. if my english awful pls forgive me. I trying to understand VHDL PROCESS statement. I try with 1bit full adder with carry save function in Quartus2 v...
11 years agoThe sensitivity list for a clocked process should only contain the clock and the reset signals. If you add the wrn and wrk signals to the list, you will create a design that will behave differently in a simulator and on a real FPGA. Quartus will ignore your sensitivity list and just synthesize as if it was (r, clk) so if you want to simulate it correctly in Modelsim you should write it as is in your code.
