ArjunTechM's avatar
ArjunTechM
4 years ago
Need a NVM IP for Agilex FPGA Devices
Currently am working with NVM SSD Devices through PCIe.
Can i get NVM IP which is compatible with the agilex FPGA Devices in Intel Pro 21.4/22.1 tool.
Any Other options to get the alternate way to develop NVM ?
Could you please provide the information as soon as possible.
Thank you.
Best Regards
Ram
  • Hello, ArjunTechM.
    Thank you for contacting Intel® Memory and Storage support.
    This issue is related to FPGA, and we will move your thread to the Intel® FPGA Software support community.
    Thank you for your patience and understanding.
    Best regards.
    Jos B.
    Intel® Customer Support Technician
  • ArjunTechM's avatar
    ArjunTechM
    Yes Jos.
    Please do the needful as soon as possible.
    Thanks in advance.
    Best Regards
    Ram
  • Wincent_Altera's avatar
    Wincent_Altera
    I strongly believe my previous reply answered your question.
    We do not receive any response from you to the previous answer that I provided.
    This thread will be transitioned to community support.
    If you have a new question, feel free to open a new thread to get support from Intel experts.
    Otherwise, the community users will continue to help you on this thread. Thank you
    If you feel your support experience was less than a 9 or 10,
    please allow me to correct it before closing or please let me know the cause so that I may improve your future support experience.
    Wincent_Intel
    ArjunTechM
    Thanks for your information on NVM IP.
    My question is Is this NVM IP will be get it from Design Gateway only other wise is there any basic design module which covers with the NVM IP Functionalities?
    my intention is can we built a deign of NVM Module without using NVM IP or not?
    If it is possible, please let me suggest if any possible ways.
    Thanks in advance.
    Best Regards
    Ram
    Wincent_Altera
    For my reachable resource, I don't see any example of building NVM module without NVM IP.
    But you can try to build of your team need to do it.
    An extra note that you might be interested to know. Where I think can share with you.
    There are two non-volatile memories on the Agilex.
    • The BBRAM that is used for encryption key storage.
    • It is only non-volatile if there is a battery connected to its power pin.
    • If you remove the battery, the contents disappear.
    • Security fuses. These are used for a variety of security functions, and are permanent once blown.
    • There are approximately 1K bits. In order to burn a fuse, the VCCFUSEWR_SDM pin must be powered.
    Hope this answer your question.
    Wincent_Intel
    Wincent_Altera
    Wincent_Intel
