ArjunTechM
4 years agoNeed a NVM IP for Agilex FPGA Devices
Currently am working with NVM SSD Devices through PCIe.
Can i get NVM IP which is compatible with the agilex FPGA Devices in Intel Pro 21.4/22.1 tool.
Any Other options to get the alternate way t...
Wincent_Altera
4 years agoHi,
For my reachable resource, I don't see any example of building NVM module without NVM IP.
But you can try to build of your team need to do it.
An extra note that you might be interested to know. Where I think can share with you.
There are two non-volatile memories on the Agilex.
- The BBRAM that is used for encryption key storage.
- It is only non-volatile if there is a battery connected to its power pin.
- If you remove the battery, the contents disappear.
- Security fuses. These are used for a variety of security functions, and are permanent once blown.
- There are approximately 1K bits. In order to burn a fuse, the VCCFUSEWR_SDM pin must be powered.
Hope this answer your question.
Wincent_Intel
