Chirs888
3 years agoNativeLink error when try to run RTL simulation
Hi, Get errors when try to run RTL simulation, The report is: Info: Start Nativelink Simulation process Error: NativeLink did not detect any HDL files in the project Error: NativeLink simu...
sstrell
3 years agoWay more info needed here. What are your NativeLink settings? What 3rd-party sim tool are you using and is the path to its executable set up correctly? Does the Quartus project synthesize correctly? What's your version of Quartus and target device?
Chirs888
3 years agoSomehow it fixed after restart. Thank you.
