10 years agoNativelink Error When Running ModelSim
Hello all,
I'm trying to run a ModelSim simulation of my project. I just installed ModelSim, and haven't gotten it to work with Quartus yet. I am running Quartus Prime Standard Edition, as well as ModelSim 10.4b Custom Altera Version (I'm not sure why it's custom...). There error comes about when I run Tools -> Run Simulation Tool -> RTL Simulation http://www.alteraforum.com/forum/attachment.php?attachmentid=11776&stc=1 I've checked the rpt file, and its completely empty, giving me no clues there. Here is Tools -> Options -> EDA Tool Options: http://www.alteraforum.com/forum/attachment.php?attachmentid=11774&stc=1 After looking around a bit, I added a trailing slash to the directories. That did not solve the issue for me. Here is the Assignment -> Settings -> Simulation page: http://www.alteraforum.com/forum/attachment.php?attachmentid=11775&stc=1 If anyone can help me get this running, it would be greatly appreciated!3 Replies
no idea about the particular problem in your case, but I had something similar when I first tried to use Nativelink on Linux. I started ModelSim manually from a shell, and there it revealed more helpful error messages (the errors were Linux-related, so I guess the details about my case don't matter here). Therefore I'd recommend to start ModelSim (the executable is called "vsim") from your installation directory using a command prompt. Maybe it spits out some more helpful diagnostics. Best regards, GooGooCluster - Altera_Forum
I'll give it a shot. However, running ModelSim *not* from Quartus doesn't yield any errors. Are you running any commands in the shell? Or are you starting the shell, and then running the EDA sim from Quartus?
This issue was not solved, however, I copied the file I wanted to simulate to a new project, and am trying to simulate it there. I don't have the error in the new project. Rather than try to solve this issue, I am just going to move on with this workaround.
