10 years agoNativelink Error When Running ModelSim
Hello all, I'm trying to run a ModelSim simulation of my project. I just installed ModelSim, and haven't gotten it to work with Quartus yet. I am running Quartus Prime Standard Edition, as well...
10 years agoHi,
no idea about the particular problem in your case, but I had something similar when I first tried to use Nativelink on Linux. I started ModelSim manually from a shell, and there it revealed more helpful error messages (the errors were Linux-related, so I guess the details about my case don't matter here). Therefore I'd recommend to start ModelSim (the executable is called "vsim") from your installation directory using a command prompt. Maybe it spits out some more helpful diagnostics. Best regards, GooGooCluster
