12 years agoNallatech OpenCL BSPs - troubleshooter
Hi, this article is aimed at addressing errors that users sometimes run into when using or installing the Altera OpenCL SDK and Nallatech 385/395 OpenCL Board Support Package (BSP). There are 4 sec...
11 years agoHi
I can use aocl install But I typed the " aocl flash acl0 base.aocx " , error message happened as shown """ This shouldn't happen: 6ee4c670-6bf3-4db4-872e-fb383606a7e3 Error: dd00cd6b-c947-40ff-95a0-41bcf30dcc31 device_id = 0x4 Unrecognised card type, so can't instantiate appropriate Flash/UFM/UCD classes! Start to Flash the device acl0 ... MMD INFO : [acl0] Reprogramming device through Flash with RBF file... aocl flash: Program failed. """"" The board problem I have been post early (about lspci) Thanks
