12 years agoNallatech OpenCL BSPs - troubleshooter
Hi, this article is aimed at addressing errors that users sometimes run into when using or installing the Altera OpenCL SDK and Nallatech 385/395 OpenCL Board Support Package (BSP). There are 4 sec...
11 years agoHi boyihuang,
--- Quote Start --- The nalla_lic.dat was downloaded from altera license center --- Quote End --- The nalla_lic.dat is provided by Nallatech (not Altera), please contact Nallatech by filling in this form to obtain your nalla_lic.dat file: http://www.nallatech.com/support-lounge-access-request The license file from Nallatech should be named nalla_lic.dat and placed at location $ALTERAOCLSDKROOT before starting the Nallatech OpenCL BSP installation. This will allow the BSP installation. You will also need the license file from Altera to compile your OpenCL SDK design (using the aoc compiler), you can place the Altera license file anywhere on your system but you will need to set the LM_LICENSE_FILE environment variable so that it points to the Altera license file location. The lspci output looks good. Thanks, G
