12 years agoNallatech OpenCL BSPs - troubleshooter
Hi, this article is aimed at addressing errors that users sometimes run into when using or installing the Altera OpenCL SDK and Nallatech 385/395 OpenCL Board Support Package (BSP). There are 4 sec...
11 years agoHi gordonei,
The latest version of the BSP R001.003.0001 was recently released, please contact Nallatech directly if you wish to obtain access (www.nallatech.com/support-lounge-access-request/). The latest version of the BSP (R001.003.0001) was tested with 15.0.0.145, previous versions of the Nallatech BSP (version R001.002.0001 and newer) should compile without issues in 15.0 as well. The Nallatech Support Lounge also hosts pre-compiled aocx for the Altera example designs (https://www.altera.com/products/design-software/embedded-software-developers/opencl/developer-zone.html#designexamples). The partial reconfiguration feature is required for OpenCL, you will need to make sure that your Altera Quartus-II/OpenCL SDK license includes that feature. Thanks, G.
