Altera_ForumHonored Contributor12 years agomy modelsim doesn't show any clock pulsing i have attached my testbench and counter code as a simple example. Im new to quartus II, so please do pardon if it is very simple to operate. I am too used to programming in C and having the benefit ...Show Moremultiple-attachments.zip1 KB
Altera_ForumHonored Contributor12 years agoThe testbench neither toggles the clock nor generates a reset signal.
Recent DiscussionsFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verificationFree Licence for Max+PlusII
