My lic is not working. I also have questasim as well. I have tried combining and separate files. Neither works. It is for Quartus Prime. Please help the support center is slow and does not answer me.
The server is running and checked it on imtools.
Warning (292000): FLEXlm software error: No SERVER lines in license file. Feature: quartus License path: D:\flexlm\1-PDLTRL_License.dat; FlexNet Licensing error:-13,128 For further information, refer to the FlexNet Licensing documentation, available at "www.flexerasoftware.com"..
Error (119013): Current license file does not support the 10M40DAF672C7G device. Go to the Self-Service Licensing Center on the Intel FPGA website to manage your licenses (https://mysupport.altera.com/AlteraLicensing/license/index.html).
Error: Quartus Prime I/O Assignment Analysis was unsuccessful. 1 error, 1 warning
Error: Peak virtual memory: 4911 megabytes
Error: Processing ended: Thu Feb 28 10:28:47 2019
Error: Elapsed time: 00:00:01
Error: Total CPU time (on all processors): 00:00:01
Error (293001): Quartus Prime Full Compilation was unsuccessful. 3 errors, 260 warnings
- JOHI
Contributor
Have you tried the quartus license without the other ones ? This way you can see where your problem resides.
Combining files does not work, I think you need to use ; or : between the different file names if you want to combine license files.
Johi.
- NBRUM
Mine is a floating lic file. If I comment out the 'USE ERVER' it brings up product
FIR Compiler, NCO compiler, FFT/IFFT.If I do not comment it out it brings up nothing. also when I try to compile a max 10 device it does not work. It throws:
Error (119013): Current license file does not support the 10M40DAF672C7G device. Go to the Self-Service Licensing Center on the Intel FPGA website to manage your licenses (https://mysupport.altera.com/AlteraLicensing/license/index.html). Error: Quartus Prime I/O Assignment Analysis was unsuccessful. 1 error, 0 warnings Error: Peak virtual memory: 4944 megabytes Error: Processing ended: Mon Mar 04 10:02:47 2019 Error: Elapsed time: 00:00:02 Error: Total CPU time (on all processors): 00:00:01 Error (293001): Quartus Prime Full Compilation was unsuccessful. 3 errors, 259 warnings - NBRUM
I finally got in contact with Altera and the lic is fixed.
