I also don't understand why you can't compile the code. I guess, the problem isn't in the shown part. For clarfication my test application that did compile.
The to_x01() point has been already discussed. It's meaningless for synthesis, but needed if you simulate I2C bus operation with a weak pull-up and open drain drivers at the slave.
library ieee;
use ieee.std_logic_1164.all;
entity test0 is
port
sel : in integer range 0 to 3;
sda : inout std_logic_vector(0 to 3);
i_sda_o : in std_logic;
i_sda_i : out std_logic
end entity;
architecture rtl of test0 is
begin
mux_sda: process (sel, i_sda_o, sda)
begin
sda <= (others => 'Z');
if i_sda_o = '0' then
sda(sel) <= '0';
end if;
end process;
i_sda_i <= to_x01(sda(sel));
end rtl;
