11 years ago
Multiplication VHDL
Hi, i have problems with my vhdl code.
can you help me plz
This is the code:
library ieee;use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use ieee.std_logic_arith.all ;
entity correla is
port (
         clk : in    std_logic ;
         rst : in    std_logic  ;
         data: in    std_logic_vector(11 downto 0)  ;
         code: in    std_logic_vector(15 downto 0 )  ;
         Q   : out   std_logic_vector(17 downto 0) )  ;
end entity ;
architecture arch of correla  is
       type RAM is array (0 to 3) of integer range -8 to 7 ;
        signal CD   : RAM;
        signal temp :integer range 0 to 15;
        signal i    :integer range 0 to 3 ;
       signal sum   :integer range 0 to 16  ;
       signal AB    :integer range 0 to 17 ;
begin
                 CD(0)<=to_integer(code(15 downto 12));
                 CD(1)<=to_integer(code(11 downto 8)) ;
                 CD(2)<=to_integer(code(7 downto 4 )) ;
                 CD(3)<=to_integer(code(3 downto 0))  ;
     étalement:process(clk,rst)
        begin
                  if(rst='1') then
                     Q<=(others=>'0');
                       i<= 0  ;
                      temp<=0;
                      AB<=0;
                   else
                        if(clk'event and clk ='1') then
                            sum<=0;
                                temp<=to_integer(data(i)*code(i)) ;
                                      i<=i+1 ;
                                  sum<=sum(i) +(temp(i)+temp(i+1)) ;
                             end if ;
                     end if ;
                        AB<=sum ;
                         Q<=std_logic_vector(AB) ;
            end process ;
 end architecture ;
    yeah !
    like this :
    library ieee;
    entity correla is
    port (
    Q :out std_logic_vector(17 downto 0) ) ;
    end entity ;
    type RAM is array (0 to 3) of std_logic_vector(3 downto 0) ;
    type ram16 is array (0 to 3) of signed(15 downto 0) ;
    type Rom is array (0 to 3) of signed(16 downto 0) ;
    signal CD : RAM;
    signal temp: ram16;
    signal sum :Rom ;
    signal AB :signed (17 downto 0) ;
    begin
    CD(0) <= code(15 downto 12);
    CD(1) <= code(11 downto 8);
    CD(2) <= code(7 downto 4);
    CD(3) <= code(3 downto 0);
    begin
    if(rst='1') then
    Q <=(others=>'0');
    temp(0)<=x"0000";
    temp(1)<=x"0000";
    temp(2)<=x"0000";
    temp(3)<=x"0000";
    sum(0)<=x"00000";
    sum(1)<=x"00000";
    else
    for i in 0 to 3 loop
    temp(i) <= signed(data)*signed(CD(i));
    end loop ;
    sum(0)<= temp(0)+temp(1) ;
    sum(1)<= temp(2)+temp(3) ;
    AB<=sum(0)+sum(1) ;
    end if ;
    end if ;
    end process ;
    end architecture ;
    error : Error (10324): VHDL Expression error at correla.vhd(55): expression ""0000000000000000"" has 16 elements ; expected 17 elements.
    55 : sum(0)<=x"0000";
    can you help me !!
    like this :
    library ieee;
    entity correla is
    port (
    end entity ;
    signal CD : RAM;
    signal temp: ram16;
    signal sum :Rom ;
    begin
    etalement:process(clk,rst)
    begin
    if(rst='1') then
    Q <=(others=>'0');
    temp(0)<=x"0000";
    temp(1)<=x"0000";
    temp(2)<=x"0000";
    temp(3)<=x"0000";
    sum(0)<="00000000000000000";
    sum(1)<="00000000000000000";
    else
    end loop ;
    AB<=sum(0)+sum(1) ;
    end if ;
    end if ;
    end process ;
    end architecture ;
    error : Error (10344): : expression has 16 elements, but must have 17 elements
    thanks a lot
    The error messages are usually quite helpful
    The answer is that the expression has 16 elements, but sum has 17
