like this :
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity correla is
port (
clk : in std_logic ;
rst : in std_logic ;
data: in std_logic_vector(11 downto 0) ;
code: in std_logic_vector(15 downto 0 ) ;
Q :out std_logic_vector(17 downto 0) ) ;
end entity ;
architecture arch of correla is
type RAM is array (0 to 3) of std_logic_vector(3 downto 0) ;
type ram16 is array (0 to 3) of signed(15 downto 0) ;
type Rom is array (0 to 3) of signed(16 downto 0) ;
signal CD : RAM;
signal temp: ram16;
signal sum :Rom ;
signal AB :signed (17 downto 0) ;
begin
CD(0) <= code(15 downto 12);
CD(1) <= code(11 downto 8);
CD(2) <= code(7 downto 4);
CD(3) <= code(3 downto 0);
etalement:process(clk,rst)
begin
if(rst='1') then
Q <=(others=>'0');
temp(0)<=x"0000";
temp(1)<=x"0000";
temp(2)<=x"0000";
temp(3)<=x"0000";
sum(0)<="00000000000000000";
sum(1)<="00000000000000000";
else
if(clk'event and clk ='1') then
for i in 0 to 3 loop
temp(i) <= signed(data)*signed(CD(i));
end loop ;
sum(0)<= temp(0)+temp(1) ;
sum(1)<= temp(2)+temp(3) ;
AB<=sum(0)+sum(1) ;
Q<=std_logic_vector(AB) ;
end if ;
end if ;
end process ;
end architecture ;
error : Error (10344): : expression has 16 elements, but must have 17 elements
thanks a lot
