10 years agomultiplication of unsigned and sfixed numbers
I am trying to multiply an unsigned number with sfixed number (0.703125). following are the code and errors:
library IEEE; use IEEE.STD_LOGIC_1164.ALL; library ieee_proposed; use ieee_proposed.fixed_pkg.all; USE ieee.numeric_std.all; entity tryproduct is end tryproduct; architecture Behavioral of tryproduct is (Line 11) signal a : sfixed(0 downto -6); signal k : sfixed(8 downto -6); SIGNAL temp1: UNSIGNED (8 downto 0) := "101001001" ; begin a <= to_sfixed (0.703125,a); k <= to_sfixed(temp1) * a; (Line 19) end Behavioral; Errors: ERROR:HDLCompiler:432 - "G:/vhdlcodes/producttry/tryproduct.vhd" Line 19: Formal <arg> has no actual or default value. ERROR:HDLCompiler:841 - "G:/vhdlcodes/producttry/tryproduct.vhd" Line 19: Expecting type integer for <temp1>. ERROR:HDLCompiler:9 - "G:/vhdlcodes/producttry/tryproduct.vhd" Line 19: Found 0 definitions for operator "*". ERROR:HDLCompiler:854 - "G:/vhdlcodes/producttry/tryproduct.vhd" Line 11: Unit <behavioral> ignored due to previous errors. thanks in advance1 Reply
Please dont cross post - there are many solutions on your post here: http://www.edaboard.com/thread353788.html
