Multiple uses of core partition
- 4 years ago
Yes, @sstrell is right. If you want to import the design partition and reuse it multiple times, you would need to choose the synthesized snapshot.
Because the final snapshot preserves placement and routing (can be assigned to only one design partition) while the synthesized snapshot does not have physical preservation (can be assigned to more than one design partition).
You may check out the documentation for the difference of partition snapshot:
Ven Ting
Ven Ting
Attached with the final & synthesized snapshot explanation.
