9 years agoMultiple RAM with different mif file
Hi all, I am doing a project to design 128 processors with a RAM in each processor. Every thing is the same but the initial data in the RAM. The design of the RAM is using the on chip memory. I...
9 years agoThank you for your help.
Did you means after generate a general ram file called ram.vhd via wizard, and copy the port to the top level module as a component. Then some how map the mif file to the corresponding ram in the top level module?
