9 years agoMultiple RAM with different mif file
Hi all, I am doing a project to design 128 processors with a RAM in each processor. Every thing is the same but the initial data in the RAM. The design of the RAM is using the on chip memory. I...
9 years agothank you for your help. I am new to VHDL, can you explain a little bit more?
I am not quite sure what is an unwrapped ram? I know how to port map the ram at top level module but I am not sure how to map the mif name to them? Thanks.
