9 years agoMultiple RAM with different mif file
Hi all, I am doing a project to design 128 processors with a RAM in each processor. Every thing is the same but the initial data in the RAM. The design of the RAM is using the on chip memory. I...
9 years agouse the ram unwrapped (expose its generics) and map at top level.
for 128 names you can use a two dimensional array of (1:128) x string length then use a loop to map the mif name for each ram
