13 years agoMultiple Nios2 cores inside an FPGA?
Hello, Is it possible to have >1 Nios2 core inside a modern cyclone FPGA? And if so, can all the Altera development tools support this sort of platform? Thanks! Lefty
13 years agoThere was another similar question a few days ago...
The advantage of SoC systems (and hard cpu on fpga) is that the cpu will run considerably faster than a Nios. OTOH the Nios is more flexible especially if you are integrating with other bespoke logic on the fpga. One of the reasons we've moved a lot of stuff into fpga is that they don't go obsolete in the same way as other components. Although the fpga itself might be obsoleted, a newer part will typically do the job and require limited rework rather than a complete redesign.
